Front KYB strut mount Bearings Placement??
Hey guys I just my front KYB struts mounts in the mail and I wanted to know how the bearing stay in place on the the mount, cause if you flip the mount over they fall out, what holds them in place?
http://smg.photobucket.com/albums/v4...t=DSC01192.jpg
see the album at link too
should be similar to your 96 , 95, not 92,93,94
here is what your 1996 suspension supposed looks like , see the parts YOU [not on my car] are supposed to have? that's why I'm saying this will make more sense when you take apart, assuming you bought the correct parts and not make an oopsie and bought 1992-1994 model year es 300 parts.
[from my photobucket this time:]
red is very important to have new parts
yellow is not a bad idea to do as well
[upper spring seat is more like orange, i would get that knowing what you are doing with your car from previous correspondance]
if it's the same, it will work ....
as far as finding the part, check with toyota dealers, too, and check more sources in general is my advice.
if your upper spring seat is in perfect condition, then it doesn't matter to replace it. but , sometimes they are all rusty and crusty and therefore musty go, so ....
I'll let you know if I find it.
after 10 minutes of searching every source i use, finally found it [so annoying to have to type so many different car names, per source!]
http://cgi.ebay.com/ebaymotors/1996-...QQcmdZViewItem
let me say that i am now checking that part no
