94 ES300 Interchangeable Parts
I have a 94 ES 300 with a smaxhed front end and need radiator, condensor bumper,grill hoods etc. I have found a 92 ES300 for a donor car. Are the parts for a 92 interchangeable with a 94 ES 300.
Thanks in advance
Thanks in advance
for the stuff you need, the parts are nearly identica;l
i would think the condensor changed when the car went to r134a for 1994. the radiator should be the same, even though the engine changed for 94, the engine is really virtually the same just different material for the block.
question, if its smashed, isnt the front crumble area parts of the frame bent in?
btw, if the donor car is a stick shift, and yours isnt, then the radiator might not work
Just the middle support was bent in and the hiid. HIt tree going low speed right on the emblem. Not fender or main frame damage. Just bumper and hood along with radiator support bracket. Easy fix. Car has 127K on it and bought for $300.00 Rest of car is in mint conidtion even interior leather.
1994, 1995, 94, cluster, compatible, end, es300, front, interchangeability, interchangeable, interchangeableparts, lexus, parts, radiator, shift, stick, wheels
