leaking transmission fluid
Old 03-13-08, 02:37 PM
Lexucan
Lexucanafer
Lexucan's Avatar
Originally Posted by GiantsInFL
my wife just picked the car up from the shop and it was leaking from the power steering. I read when i was looking about leaking transmission fluid that people use transmission fluid for power steering.. so it got fixed, at least its not the transmission. I added some transmission fluid to the transmission thinking, and told, it was that initially... will that hurt the transmission?
How much ATF did you add? Just check your transmssion dipstick to see what it's reading. Too much ATF is not good.
Old 03-13-08, 03:47 PM
GiantsInFL
GiantsInFL's Avatar
how would I drain some?
Old 03-14-08, 08:26 AM
Lexucan
Lexucanafer
Lexucan's Avatar
From the Lexus ES300 FSM:
1. CHECK FLUID LEVEL
HINT:
Drive the vehicle so that the engine and transaxle are at
normal operating temperature.
(Fluid temperature: 70 – 80C or 158 – 176F)
Only use the COOL range on the dipstick as a rough reference
when the fluid is replaced or the engine does not run.
(a) Park the vehicle on a level surface and set the parking brake.
(b) With the engine idling, and the brake pedal depressed, shift
the shift lever into all positions from P to L position and return
to P position.
(c) Pull out the transaxle dipstick and wipe it clean.
(d) Push it back fully into the tube.
(e) Pull it out and check that the fluid level is in the HOT range.
If the level is at the low side, add fluid.
NOTICE: Do not overfill.
If your ATF level is too high, there is a drain plug on the underside of the transmission for removing fluid. Just untighten the 10mm Hex bolt enough to that the ATF starts to leak out. When you've drained (more than) enough, retighten the plug. Then recheck your fluid level at the dipstick and top up with new ATF to full level.
Old 03-14-08, 03:10 PM
GiantsInFL
GiantsInFL's Avatar
on the way home last night, the engine blew. An now the dealership is saying that they are washing their hands of the situation, Im stuck with a $4000.00 paper weight.
Old 03-14-08, 05:09 PM
Lexucan
Lexucanafer
Lexucan's Avatar
What do you mean by "blew"?
Not at all surprised that the stealership is walking away. That's exactly what POS low-lifes do in such a situation.
Old 03-14-08, 06:57 PM
kphu
kphu's Avatar
Is there a lemon-law in FL? If so look into that even though you signed an AS-IS in MA I think the lemon-law still applies.
Old 03-17-08, 05:09 AM
GiantsInFL
GiantsInFL's Avatar
no used car lemon law in FL. And my mechanic said that gaskets werent done right on the engine and the head blew. Im going to sue the dealership, not for the car because I did sign as is, but for the work they did on the engine and blowing up on me. I hope I can get somewhere with this, I also contacted news channels, consumer reporters, and let them know my story. I hope at least one responds, Im not counting on it but you never know.
Old 03-17-08, 06:39 AM
Lexucan
Lexucanafer
Lexucan's Avatar
Im going to sue the dealership for the work they did on the engine and blowing up on me. I hope I can get somewhere with this, I also contacted news channels, consumer reporters, and let them know my story. I hope at least one responds, Im not counting on it but you never know.
Great idea!!! Wouldn't those POS's be surprised if a reporter and camera crew landed on their doorstep! Good luck!
Old 03-17-08, 08:43 AM
powerwave
powerwave's Avatar
oh man, i'm so sorry
at least go after them for the head gasket job- they have insurance to cover their liabilities for that. they can't just say it's not their problem. they should be buying you a new engine, and paying for SOMEONE ELSE to install it.
Old 03-17-08, 11:09 AM
GiantsInFL
GiantsInFL's Avatar
yea thats what Im hoping for. I wanna talk to a attorney soon to see what grounds, or even if I have any, do I have to sue this POS dealership.
rarebmx4me
Performance & Maintenance
06-02-19 01:54 AM
UGAALF
05-13-16 10:18 PM
RXGS
39
07-25-12 10:43 PM
Gdfela400
05-15-11 09:20 AM
Quick Reply: leaking transmission fluid
