What ATF Do You Use? (Maintenance)
Old 03-26-08, 11:31 AM
ThePill
ThePill's Avatar
Default What ATF Do You Use? (Maintenance)
Like The Title Said, What ATF Do You Use For Your Power Steering And For Your AT? Also How Often Do You Drain & Fill Your Power Steering And Your AT?
Old 03-26-08, 11:34 AM
Lexusfreak
Lexusfreak's Avatar
Cool
Amsoil synthetic ATF for both here (compatible with Toyota Type IV & Dexron III fluids). Done every 2 years or 30k miles.
apham8 (11-11-23)
Old 03-26-08, 12:08 PM
kingofire
kingofire's Avatar
redline every 90k miles for both. I am a firm believer in if it aint broke dont fix it. I also have a 2006 ES that requires less preventative maintenance than older ES's.
Old 03-26-08, 02:14 PM
captain313
captain313's Avatar
amsoil for everything myself.
Old 03-26-08, 02:27 PM
jet_jockey
jet_jockey's Avatar
i've used valvoline max-life with no problems at all. Usually change it once a year/every 5 or so 5k oil changes. (I drive alot, though).
Old 03-26-08, 02:41 PM
ThePill
ThePill's Avatar
i just bought some Valvoline MaxLife DEX/MERC ATF is that good? or should i return it and get something else?
Old 03-26-08, 03:22 PM
llcoolpass
llcoolpass's Avatar
any mercon dexron that you find in the parts store is perfectly suitable for both the power steering and the transmission.
some people seem incredulous to hear ''automatic transmission fluid'' goes into the power steering. Message me if you need an explanation or other clarification.
right now the latest stuff I think is IV, that's works too since it super cedes III and super cedes II
all the brands shhould be just as good. get the cheapest and youll be fine. just change it out every 30 K miles. or if the car is newer, get it flushed out, but only if new, because old cars may experience transmission problems after a flush due to debris clogging solenoids.
you should also remove what you can from the power steering reservoir and refil, every year, so as to be equal [dillution method] to doing it every 2 years. Of course, if you run the wheel to lock frequently, that would necessitate more frequently replacement.
Old 03-26-08, 04:07 PM
Lexmex
Super Moderator
Lexmex's Avatar
I use Mobil 1 ATF for the PSF, Toyota Type IV for the moment in Mexico, but will be switching to Amsoil on the ATF when I get to Florida next month.
Old 03-28-08, 01:56 AM
smokesgtp
smokesgtp's Avatar
I use the maxlife dex/merc. They claim the base oils are synthetic. Seems good to me. I do a huge amount of stop and go so I do a drain every 2nd oil change or about 14k.
Old 03-28-08, 10:47 PM
llcoolpass
llcoolpass's Avatar
damn your car must be in great shape, hardly anyone does that
mad props to you
Dallasguy1
GX - 2nd Gen (2010-2023)
82
03-31-24 08:14 PM
wsrivers
04-06-17 02:24 PM
dbui
RX - 1st Gen (1999-2003)
07-03-13 04:30 AM
metaron
Maintenance
01-19-11 08:22 AM
dshahs420
Maintenance
07-26-06 06:29 AM
Quick Reply: What ATF Do You Use? (Maintenance)
