Timing Belt Change
Old 03-29-08, 12:43 PM
LexusPhan
LexusPhan's Avatar
Default Timing Belt Change
What else should be changed out at the same time the belt gets changed (1997 ES300 / 190K miles)
Old 03-29-08, 02:03 PM
JSM1284
JSM1284's Avatar
Timing Belt, Water Pump, Thermostat, Spark Plugs.
Your car would love you.
Old 03-31-08, 02:43 AM
jet_jockey
jet_jockey's Avatar
don't forget valve cover gaskets
Old 03-31-08, 06:31 AM
llcoolpass
llcoolpass's Avatar
to add to the previous things said:
the following timing belt components should be replace: the idler, the tensioner, and the hydraulic tensioner
the two drive belts should also be changed at this time.
so it's timing belt, the components, the water pump, the spark plugs, maybe the thermostat[so cheap], the valve cover gaskets, coolant flush [if doing water pump], maybe the spark plug wires.
inspect condition of the accessory pulleys and motor mounts before doing, as well as a host of other things.
Old 03-31-08, 08:27 AM
paintrain
paintrain's Avatar
^^^ yep ^^^
as far as everything else, timing belt and serpentine belts should be replaced. id only replace the water pump if it looked a little shabby. the tensioners should be fine. just check to make sure the pullys dont have a wobble to them when the car is running, they might need tightened up or replaced. but chances are youd notice some sounds that would clue you in to the pullys needin replaced
Old 08-19-09, 02:08 PM
Trexus
Trexus's Avatar
I just had my timing belt and tensioner replaced yesterday by a friend of mine.
Timing belt $40
Tensioner $70
I paid my friend $150 and he also replaced the drive belt at no charge. What a guy! I changed the water pump at 270K and I'll replace it again at 450K miles...
Old 08-19-09, 02:35 PM
tromly
tromly's Avatar
Timing belt $40
Tensioner $70
Please send us pics when it hits that 450k mark
Old 08-21-09, 05:45 PM
Parker Gen
Parker Gen's Avatar
Timing belt $40
Tensioner $70
Haha 450k mile!!! That's huge.
ak22801
IS - 1st Gen (2001-2005)
01-25-11 09:38 AM
diverchris
09-10-10 02:05 PM
shajbot
Maintenance
01-20-09 01:47 PM
Two bit
01-02-08 08:26 AM
Och
05-15-06 08:01 PM
Quick Reply: Timing Belt Change
