i have a small probably, try to help me out
so i posted that i got a 00 platinum edition, i threw on some new tires rear brakes rotors spark plugs and a new fuel filter, the problem is when the car is in idle or im driving and i tap the gas quickly there is a slight delay or when im driving its kind of a slight jerk. like the rpms will pause for a split second but its kind of noticeable, the car shifts smooth in all gears, i also tryed seafoam and lucus anyone got any ideas
thanks
thanks
When you initially step on the gas pedal is it smooth or does it seem to have a little tension? If so then there's 1 of 2 issues that can be happening or both. The first is that the throttle cable is sticking somewhere. The 2nd is the butterfly valve in the throttlebody is sticking due to carbon build up. You can take carb cleaner or throttle body cleaner to clean it out. Cheap thing to do - $3 for a can or 2 of cleaner and some of your time.
This was what happened to my sister's camry from using cheap gas over a long period of time.
Good Luck
Good Luck
seafoam will only clean it out if it gets into the spot having the issue. If you remove the hose connected to the throttle from the air filter you should see a butterfly valve. Turn it and look inside. If it's dirty then spray some carb cleaner and clean it out as much as you can.
im gunna go out on a limb and say nutin is wrong. 8yr old lexus isnt gunna have the best throttle response in the world. but, no one says you cant do things to improve it
