Tried to mod the AFM... Problems!!!
Ack, well i thought i had done it right until today...
I had modified my AFM by adjusting the cog 4 click lean and reseting the ECU. That was a day or two ago. On my way to my friends house the idle dropped at a stop light and my O/D button started rhythmically flashing on and off. The car seems fine when it drives but almost dies at idle and seems sluggish, could this be due to what i did? What does this mean?
Basically.... Help.
Basically.... Help.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Update with questions:
Aamco said the speed sensor had seized up and melted causing liquid plastic and nylon to leak into the transmission causing all hell to break loose. They put in a brand new transmission and a new speed sensor. They gave my ES back to me with the ABS light staying on. They said it's on because they had to run the car on the rack with the wheels off and said it would go away after 100~150 miles. Would what they did cause the light to come on and will it go away?
ZYTRAM
01-03-17 07:22 AM
h4vok
18
09-09-09 06:20 PM
