Oil Filter Stuck!!! Any Oppinions, Thoughts, Suggestions (PLEASE)
(Solved w/ Pics) - Oil Filter Stuck!!! Any Oppinions, Thoughts, Suggestions (PLEASE)
I'm not to experianced when working with cars so I usually have my father do the oil changes. After watching him a few times I was able to learn how to do this maintenance procedure. So now its time to do the oil change again (for my 2nd time) and now I can't get the oil filter OFF!!!!!!!!!!!!!!!!!!!!
It seem to be on there so tight that after a few trys to loosen it, the filter is all dented from two tools we tried to get it off with.
Problem solved. Didn't find that one at autozone but found something rather similar show in the third picture. I wanna thank you for your help and heres the end result.
I once punched a screwdriver thru the filter and used that as a lever to get it off. A bit messy but it got the job done. Make sure you oil the gasket and get the old gasket off.
Yeah only go 3/4 to one full turn after hand tight. The mobil one is already lubricated but i put a little oil on there anyway. I've had to use a screwdriver myself it is a messy procedure. Good info on the fram too they're garbage. Don't forget to fill the filter with a little oil as well b4 you put it on.
99custom
02-25-18 07:54 AM
