95 es300 still not starting
I Still Have Not Been Able To Get This 95 Es300 Started. The Fuel Pump Initially Went Up When The Car Was Brought To Me. Replaced The Plenty Of Fuel Now. There Is No Spark Now. I Tested Both The Cam And Crank Sensor Both Were Fine. I Also Do Not Think There Is An Injector Pulse. That Leaves Me To Believe That The Computer Is Bad. Does Anyone Else Have Any Insight.
whatever it is you do, go with dead ecu last
also, let us know if any of the advice given so far has panned out. i got more ideas if no one else does once you've done that [already one thing im not sure if you definetely checked stuff that would have ruled this out, but timing belt issues]
igbeserk
05-02-09 08:45 PM
