Another rim question...............
Ok if I pick up this guys MRR HR2s he has staggered 18x8 fronts and 18x9 rears. What size spacer am I going to need for the rears? I don't yet know the offset he hasn't let me know yet. Probably won't find out till I go and see them this weekend. Oh and what size tire should I run on the rears. I know 225 for the fronts but not sure what to do about the rears maybe 235s? He's running 245/45's I think this is coming off a truck. Also is there any problems I'm going to run into. I remember someone posting that they ran into problems when they did their IS rims that were 8.5's in the rear.
i have a 94 es300 and i have 18x8.5 all around and i am selling them now for 8 inch wides because in the rear they stick out to far so therefor when i hit bumps and the shocks raise and lower my wheel wells rub on the tires. i dont know if it is a diff. spec for the year you got but i wouldnt go bigger the 8 inch wide
Thanks,
If you want perfect fit then theres no better way then getting wheels custom built to your needs. ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I got 18x8.5 +25 no spacers needed,hella flush approved...if i ever mount them!
![](http://i32.tinypic.com/2d0josj.jpg)
![](http://i30.tinypic.com/2ylo0o6.jpg)
Ok about offset for 8.5 width you want anywhere from 25mm to 35mm. When it comes to spacers I have 12mm and I'm still dangerously close to the strut. I am about to lower it and am going to fin out if I need to roll the fenders as well. RJ-es300 what size tires are you running cuz I don't rub when I hit bumps yet...
