2001 Lexus ES300 Airbag light is ON. Need help fixing.
I was cleaning the Lexus so I took out both front seats and back and then the lower part of the dash board.
Reason: Cleaned Carpet.
Problem: I re-put everything back in the same way I took it out. I connected everything the same. Someone said that under the seat the battery wasn't connected or something, but it is. I herd there are also air bags in the seats?
Tried: I have tried what people said online about reseting air bag lights. I tried disconnecting battery in the certain way and I also tried putting the key in "ON" position and then opening the door and pushing the door sense? button 5 times and then shutting the door and turning the car on.
Question: How do I reset the computer or whatever needed to reset the airbag light and make it disappear without going to the dealer?
I know that when the airbag light is blinking, that means there is a problem, but mine is just steady ON.
Thank you for any suggestions you may have. If you need some more info, please post.
I have the same problem. Although I bought my car and the light was already on so I don't know if someone pulled out the seats or if there's another way to diagnose the problem.
Thanks,
Doug
Thanks,
Doug
Hattrix
01-01-15 11:22 PM
