QUESTION :I'm replacing low beam bulb on 2002 ES300
Hello,
I'm going to replace the low beam bulb on the passanger side. Anything I should be aware about before I do it. I know I shouldn't handle the bulb with out gloves, but is there any else that I might run into a problem with. Also can I just buy the bulb at a local Auto Zone or do I need to go to the dealer?
Thank You
Keeper02
Thank You
Keeper02
Ok Guys.. I called Lexus of Manchester and they pricing HID bulb for $343.00. That is crazy ! I went to VIP and picked one up for 90 bucks. I replaced the buld and still it didn't work. I noticed my parking light is on. Is that like a backup light in case of course the low beam isn't working? I Also noticed when looking at the light cover it had some condensation inside it. I checked all the wires and didn't find anything. I checked the fuses just in case and found nothing. I also switch the bulbs from one headlight to the other just to make sure the bulbs were working. So what could it be?
thanks
thanks
velani
09-06-16 12:47 PM
