Gen 2/3 Window Alignment
The front part of the window goes up like 1/4 an inch higher and it has broken through the rubber weather seal at the top. Its causing a lot of wind noise since the seals are off.
I pulled apart the driver's side door panel, and took off the black plate and tried adjusting the window with directions from the factory service manual.
I tried adjusting the window stoppers, the three bolts that hold the window to the window plate, but the only thing it would do is shift left to right. I just gave up and put everything back on![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Anyone has had their car windows realigned before?
I wanted to make the front part of the glass go down 1/4 inch. (the part where the mirror is)
When i pushed down on that part, the other side went up, and its not going anywhere
