60 k service really needed?
Old 04-30-08, 06:34 AM
Antphilli
Antphilli's Avatar
Angry 60 k service really needed?
i have a 99 es 300 coach edition with 52 k on it... 60 k is coming fast, do i really need get the 60 k service for around $2000? any other options? thanks.
Old 04-30-08, 06:57 AM
LexGrl702
LexGrl702's Avatar
$2000?!?!?! That sounds like a rip off to me. Is that from the dealer? Don't take it to the dealer, just take it to a good mechanic who specializes in Lexus or other luxury cars. I have a 2005 and was only quoted $350 for my 60k service.
Old 04-30-08, 07:27 AM
19psi
19psi's Avatar
a 60k service is very important. all belts, filters and fluids are changed. fluid changes make the difference as to how long your engine, trans and brake system lasts.
Old 04-30-08, 08:51 AM
Antphilli
Antphilli's Avatar
Talking
thanks everyone... $350 sounds better lol...
Old 04-30-08, 09:25 AM
jjbodean
jjbodean's Avatar
$2000 would be for a 90k, t-belt, water pump, etc. a 60k should run about $700 to $800 i would think at the dealer.
Old 05-01-08, 12:43 AM
OceanView
OceanView's Avatar
waste of money man.
My 98 has 247K miles on it and all I do is Radiator/transmission/oil/filter and it has been fine.
YMMV
Old 05-01-08, 07:07 AM
19psi
19psi's Avatar
you've never done a timing belt, air filter, or brake fluid flush in 247k miles?
Old 05-01-08, 07:52 AM
KayGee
KayGee's Avatar
Originally Posted by OceanView
waste of money man.
YMMV
Have you owned it for the entire 247K miles?
Old 05-01-08, 08:07 AM
Infin1ty
Infin1ty's Avatar
I'm coming up to my 120,000 mile service here soon. I wasn't going to get it done, but with it goes into the shop the day after I bought the thing, I'm not taking any chances.
Old 05-01-08, 01:24 PM
19psi
19psi's Avatar
yeah make sure you get that tim8ing belt changed with the 120k, unless you had it done at 90k.
Old 05-03-08, 03:47 AM
smokesgtp
smokesgtp's Avatar
Change the plugs,filters, etc. Trans fluid. Serp. belt if necessary. Coolant if it doesn't look good. No need for the stealership. You have to remember most people never change brake fluid until they have a problem. Same goes for power steering.
Old 05-03-08, 03:53 AM
llcoolpass
llcoolpass's Avatar
i find even car 'experts' grossly under educated on brake fluid.
you have to change the brake fluid every 2 years, you might be able to do it less in a really dry climate AND rarely driven vehicle. else, you will end up with more problems, thus making it cost ineffective to not change it.
Old 05-03-08, 10:48 AM
Infin1ty
Infin1ty's Avatar
Ironicly, that it what put it in the shop, the timing belt and a couple of sensors are causing it to misfire.
Old 05-04-08, 10:31 PM
OceanView
OceanView's Avatar
yes I've done these, timing belt not until 90k.
I assumed he was aware of 15K for air filter and brake fluid every 2 years.
Old 05-04-08, 10:33 PM
OceanView
OceanView's Avatar
Yes, I am the original owner.
Quick Reply: 60 k service really needed?
