outside temperature button
REF: HEATING & AIR CONDITIONING
NO.: AC001-95
DATE: MAY 3, 1996
MODEL: LS 400, GS 300, SC 400, SC 300, ES 300
Title AMBIENT TEMPERATURE DISPLAYS -22°F
On Lexus models equipped with an ambient temperature display, -22°F may appear in the ambient temperature display if continuity through the ambient temperature sensor circuit is interrupted. Since the -22°F is retained in memory, the condition will persist even after continuity through the ambient temperature sensor circuit has been re-established. Climate control system operation may also be adversely affected.
This condition can be corrected by briefly removing the fuse supplying the B+ power source to the air conditioning control unit.
Do not attempt repairs before performing the following reset procedure:
Refer to the table and remove the appropriate fuse for 30 seconds and reinstall.
IMPORTANT :Some of these fuses provide power to other systems for memory retention. Check and reset clock, radio presets, and memory as necessary.
If ambient temperature display is not corrected, refer to repair manual for diagnosis.
NO.: AC001-95
DATE: MAY 3, 1996
ohh the fuse box by the filter box kinda? and all i gotta do is pull it out than put it back in? sorry im a noob with cars and i dont trust people in my town with a lexus.... im one of the few that own one! lol
mmk i opened up both fuse boxes...
the skinny small one and the big fat one
i dont know which fuse to pull? none of them said ecu b
my friend told me to just pull my negative off of my battery it will reset the whole ecu
idk man... my friend took the bumper off and all of the sudden its like that?
maybe the bumper triggered something? idk... but i want to get it fixed i dont wanna go to the dealership........
is there a plug? maybe its unpluged?
the bumper reinforcement the big bar in the front... is it behind it? left or right or below it? im puttin the bumper back on today its gonna be finished would like to fix the temp sensor before
btw thank you jsm for your kindness and help
can someone please help me locate where it is supose to be wired up at? i heard left of the right headlight but i see nothing?? dealership costs $$$$ just to look at it!
i took out the ecu b fuse but the car was off does that matter? do i have to do it while the car is on that way the ecu is on? would like to fix this before i put my bumper back on its almost finished
The sensor is either located on the bumper reinforcement(big metal bar the bumper goes over), or located on the bar that goes from the upper to lower radiator support, Under the hood latch. make sure there arent any wires hangine loose not plugged in
