Question Regarding Fast Blinkers (1996 ES300)
Alright heres the pickle, when i use my caution flashers they flash in a normal speed, only on the back tho, i just replaced the bulbs in the front and i still aint getting nothing, neither on the fog lights, checked all fuses, nothing wrong.
Anyone have a similar expirence to what im dealing with? what would be the quickest and cheapest way of fixing the problem?
Could also be a fuse, look at your manual and you will be able to find which fuse you would need to look at, if it looks very black, or burnt, you should go ahead and replace it. Fuses are pretty cheap, so you should probably pick some up whether or not you actually need them.
new_berlin
06-10-19 06:41 AM
marcmindte
10-30-05 01:52 PM
