Broken window switch?
Hello Lexus Fans
The window button for the driver side window will not bring the window up or down automatically. I have to hold the button down manually (like I would do if I was in the back seats) The passenger switch next to it is working ok. Could it be the switch itself going bad or something expensive in the window motor
Thanks in advance!
my drivers side switch for the passenger window will not go down but i can pull it up no problem? idk just bugs me when i want to put my windows down and i can only do 3 from my side and reach over and get the passenger side down any input?was gonna make a new thread but you have same problem almost
Same with my driver's master window control switch. The passenger down switch will not work, but will go up VERY slowly.
This is because of corroded contacts...and its almost impossible to fix.
Its very easy to do a diy replacement.
All you have to do is take off the door panel, and unscrew the switch from the back side and replace.
Lexucanafer
KiNGD206
01-10-14 07:13 PM
misterlv
06-09-12 12:42 PM
