Retro fit 92-94 ES300 Fogs light on my 96 ES300
Hey guys I was thinking about swapping my 96 ES300 Fogs to the yellow circular fogs from a 92-94 ES300 and wanted to if anyone was interested intrading mine for yours including the lower grille of course or if you guys know where I can get these for a good price. I tried the local junkyard with no luck and I found the fogs on ebay but not the lower grille. The reason I want these is because I cant get a true yellow with my current fogs, I tried PIAA plasma yellow and Luminics JDM Yellow H3bulbs but cant achieve the yellow that the 92-94 Fogs produce.
I found these on ebay but dont know if the wiring is the same as USDM since they r JDM but they r in great shape.
They are the same. They will clear the 95-96 grille as well. Dont' bother swapping the lower grille, since they look just as good with the 95-96 grille. When you get them, make sure to open them up and clean up the interior housing as well as the lenses. The great thing about these housings are that you don't need to bake it!
Simply take out 4 screws. Would be easy to put in some 3000k hid's and do a Custom shield for crazy color shift.
All wiring harnesses will fit, and bulb size is H3.
Make sure the ebay fogs are not from frontal collision cars. Mine had a crack in the rear housing which i had to seal with rubber silicone.
Wow! that looks good dude, where did you get them cause they look brand new and where they JDM or USDM but I heard that the fogs from JDM work fine on USDM no wire slicing just direct plug and play and it looks just fine with the 95-96 grille.
