need help on 99 es300 fault codes p0330,p0325,p0441,p0446
my es300 has about 107,000 runs great ..but the check engine light on
scan the codes and this is what came up ...
p0330 knock senor 2 curcuit 2
p0325 knock senor 1 circuit
p0441 eva system incorrect purge flow
p0446 eva emission system vent control circuit
i search all over and it seems i have 2 bad knock senors ...
and the fuel evaporative system ......
how should i go about fixing this should i get the 2 knock senors change first
..or deal with the fuel evaporative syetem ...
what can i change there first
gas cap ?
or the whole cannister .. or what part ...
one more thing is there a site where i can buy a shop manuel ....not hanyes
a real one ..cause i dont know where nottings at ?
thanks for your help
gas cap ?
i just replaced my canister last night. fairly easy. only about 1-1.5 hours of labor, and costs anywhere from $200-$350. my vehicle is a 97 and it required charcoal canister pn#77740-03063 if i remember correctly. i believe if you have 0441 and 0446 together its a canister issue. or you can try just the vsv p# 77740-12271. approx $50. and the part is a crossover part, and it has been slightly changed from 97 year vehicles. as for the rest. goodluck. i have yet to have those issues.
Charley
Charley
i been looking for that part the canister assy on line couldn't find the p/n
and where is it located on the car i tryed to find the pics on line but couldn't get it ..is it in the fender ...in the diagrams it looks like its at the end of the air intake...will that p/n 77740-03063 fit my car ...and is the vsv on the canister itself ? thanks so lost ...trying to fix this code and have a shop take care of my knock senors..by any chance do you know the p/n for the harness
thanks so much for your input ?
ill double check when i get home tonight, i believe its pn 77740-03063. and it has the vsv 77740-12271 on it already. but like i said, it might just be the vsv, but chances are 0441 and 0446 are canister IF i remember correctly. it is located under the air intake, held on my 3 10mm hex screws. fairly easy. search "charcoal canister" and i believe my most recent post should be 2/3 down. i paid 314, because i couldnt wait any longer, toyota and lexus were both same price.
Charley
its not in the fender. its on the drivers side, under the airbox. b/w the brake master cylinder and fuel filter. its a black box, with 2 round things on top, with probably 6/7 vacuum lines coming off.
Charley
thanks for the help ..i haven't had a chance to look for the canister ..but in my reading you say ints under the intake ..and in other post its under the the fuel tank ..lost and since when i get off work it will be dark ..wont be able to check it ...about to oreder 77740-33062 do you kno w of any good site with good priceing ...
flashprash
08-17-21 05:59 PM
FrankDavis
03-23-10 06:46 AM
