Window Problem
I'm new to this, this is actually my first post
Ive had my 95' ES300 for about 2 months now and the Passenger window and Rear left drivers window wont go down.
Do you guys got any suggestions what it might be? My original guess was it was the motor but i don't know maybe there might be other alternatives that could save me some cash.
Both windows that are malfunctioning are diagonal from each other, is there maybe some diagonal wiring problem, since the ones that do work are also diagonal from each other. (I'm not sure if windows are even wired that way but it was my guess)
-Ricky
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
-Ricky
I know it seems like a simple thing, but you have tried to put the windows down from the driver's seat, and the seat that the window is at, right?
Could just be a falty switch.
If they both went out at the same time, it could be a fuse.
The motors could also be dead.
Yeah ive tried putting the window down on both switches, the drivers seat switch works just fine because it puts my 2 other windows down.
Know how much a motor is going for?
it was my regulator itself , the cable became binded and messed up. the motor still wanted to work.
i got the motor®ulator totgether, the way they are supposed to come just so you know, in what's called the window regulator assembly, for about 50 dollars months ago at a junkyard in philly.
-brian
ps the window is heavy and its best to have assistance of another person
-brian
andybisnut
08-28-12 11:29 AM
