1998 es300 Aftermarket wiring
Hey, will be installing a aftermarket headunit in the up coming days. For the people who has already done this, do i need a wiring harness?
I found this on ebay
http://cgi.ebay.com/ebaymotors/Lexus...mZ350059023588
It be great of someone tell me if I need this or not.
Thanks
Thanks
yes, that wiring harness will work. don't connect the ground or yellow wire through the harness, if you do, then you will get a ton of engine noise. run those two wire straight to the battery terminals and this will eliminate any engine noise. this is what happened to me when i installed my alpine w205.
RumpRoast
09-20-09 03:48 PM
