Engine Oil Leak (Rear Seal)
My 93 Es had a oli leak, I'm not sure where it is comming from,
Has any one had a oil leak on a ES ?? I have 187,000 Km on it,
thats over 100,000 Miles.. About every 2000Km, I need to put in
200ml of oil ( I know its not much but you can see oil around the engine block). Does anyone know what seals must be replaces?? Please help. Is this a common problem with the
engine??
engine??
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Looks like you need new valve cover gaskets. You can pick them up from Discount Auto Parts for abour $30. The front one is easy to change out(just unscrew valve cover, and take it off and change valve cover gaskets). The back one is more difficult as you have to take off the intake manifold. I dont suggest trying to do this on your own, unless you have some kind of engine mechanical background or knowledge.
