P1155 & P1150 fix
P1155 & P1150 fix
O.K. so about a week ago my CEL and TRAC OFF light iluminated.
Here is the reading that i got from checkers
Location of Bank 2 Sensor 1
Ordered this part from ebay 89467-48011, only to find out that the harness connector did not fit on the other end.
Now the p/n: 89467-41040 is what i removed. So obviously i ordered the wrong part. What i did was cut the old a/f sensor connector and solder it to the new a/f sensor, with heat shrink tubing and all that.
Here's a pic of the old a/f sensor i pulled out.
Tools you might need for removal of the sensor. luckily the sensor was not siezed in the intake manifold.
After i replaced the defective part, i went back to checkers to rescan and clear the fail codes. During the scan process it pick-up 2 other fail codes that i did not see before. After scan was complete i cleared all the fail code and rescan again. The final scan did not show any fail code, so i was happy with it and now i don't have the CEL and TRAC OFF light no more or for now. It's too early to tell, crossing my fingers.
