Suggestions/advice for Xenon headlamps upgrade?
I just bought an 05' ES 330, it has all of the options I could possible want/need except for the bi-xenon headlights. My previous G35 did and I miss them. Is there anything I can do to get dealership quality Xenon's on this car?
I suggest buying Lexus factory HID headlamps (projector or reflector), a wiring harness and ballasts online and swapping them out. It's expensive, but will give the factory look and is much easier than retrofitting projectors into the halogen housing. Unless you are a pro retro-fitter like JSM
Thanks...
Thanks guys. Since my wrench turning abilities are about on par with a 3 year olds, I decided to have a shop here in town do it. You are correct, it is expensive, but since I've had the HID's on my last two cars, I just couldn't not have them on this one.
They are pretty big. But could probly be done with quite a bit of modification.....
It would be easier to retro them into a stock ES300 reflector housing lamp and add a custom shroud....
zuluzulu
RX - 3rd Gen (2010-2015)
06-20-17 06:33 AM
