Car Won't Start on First Try
My wife's '02 ES300 has suddenly stopped starting on the first attempt. It seems that it is like this any time the engine cools off a little. The reason I say this is if you turn the car off and try to start the car again after you finally get it started, it will crank up with no problem. Starter? Any ideas?
When cold, have someone turn and hold the key, if its not cranking while holding the key, pop the hood and tap on the starter with a blunt screwdriver or something. If that works, then the most likely cause is the starter.
Where's the starter? lol. I'm a complete under the hood newb but I plan to change that this summer by doing a WHOLE lot of reading and stuff. Sorry for the late reply. CL doesn't like to send me emails sometimes.
Mine went on my 97 the other day. It would click once (no other noise) and if I kept trying it would eventually suddenly turn over and start, but each week I didn't have it fixed, it got worse and worse untill it wouldn't start anymore after trying numerous times.
Before you spend heaps of money on buying a complete new starter motor get your auto electrician to check the contacts inside the starter motor because in almost every case all you need to do is replace the starter contacts inside the starter motor. This is basically the only things that wear out on the Lexus/Toyota Denso starter motor. Act like you know whats wrong with it and say its the contacts when you go to the electrician because many will simply try to rip you off by saying you need a brand new starter!
Check this out..... Their advice certainly worked for me and I saved heaps - just needed new contacts. Simple!
http://www.startercontacts.com/
Good luck!
LEX ES300
