Right Side Drive Shaft(Axle) Removal Help
Old 06-06-08, 05:48 PM
Carbon~IS
Carbon~IS's Avatar
Default Right Side Drive Shaft(Axle) Removal Help
I'm in the process of replacing the Right(Passenger) Side Drive Shaft(Axle) on a 98 ES300.
I got everything off on the Hub side, + the Snap ring and the Lock bolt by the center bearing. I tried to take the drive shaft out, and it wouldn't budge. After spending couple of hours on it, I went and checked the FSM to make sure that I didn't miss any bolts or snap rings.
According to the FSM, it's suppose to just come out after you take the bearing lock bolt and the snap ring.
I spent the last 2 days hammering, pulling, heating it up, and lubricating w/ pb blaster, with no sucess on removing the drive shaft/axle... My only guess at the moment is that the center bearing is stuck in the carrier. I think it might have happened from the accident when my aunt ran over a curb breaking the wheel and bending the lower ball joint. Or maybe it's stuck from the built up rust??? Either way I need some suggestions on how to remove this thing...
Thanks~
Old 06-06-08, 06:34 PM
swifty562
swifty562's Avatar
best way to do it, hammer it out.
mines was stuck in the axle holder or whaterever its called.
also, it was rusted and i finally got it out after an hour of hammering.
Old 06-07-08, 05:10 AM
llcoolpass
llcoolpass's Avatar
pry bar at the trans works on some cars
axles can just be so annoying to get out. im going to remember what swifty says for when/if i do axles onthis car
Old 06-07-08, 03:16 PM
charley240
charley240's Avatar
yeah, that center bearing has a snap ring, and the underside of that bearing holder has a 14mm? if i remember correctly. from there, it should just slide out. at least mine did.
charley
Old 06-07-08, 06:14 PM
GEORGE_JET
GEORGE_JET's Avatar
There is a tool, that looks like the old pac man, goes on the end of a slide hammer. You slip the cutout over the axel (between the cv and tranny) and then pound away on it. You should be able to rent this at a good rental place. If it is really stuck, you could also try removeing the other side, and then using a long punch to try to push it out of the differential.
Tank
Suspension and Brakes
04-12-18 08:12 PM
grandamliz
109
06-18-17 11:00 AM
5t341th
21
06-13-13 03:28 PM
wolfalp159
GX - 1st Gen (2003-2009)
12-02-12 03:58 PM
//LRD
Florida Lexus Club
227
08-21-11 03:30 PM
Quick Reply: Right Side Drive Shaft(Axle) Removal Help
