P0125 and P1135
P0125 and P1135
Board,
I have searched all over this and another lexus forum, but end up being confused about what I need to do. I have an es300 1999, i have the CEL and TRAC off lights on. I have the codes read: P0125 and P1135.
I am confused about doing something with the MAF and doing replacing the 02 sensors.
Any advice as to where to start?
THanks
Russelltw
THanks
Russelltw
so far, I have replaced the air flow sensor after the air intake filter. I am still getting the p0125, p1133, p1135. I had it reset a couple times to make sure it was not a false reading. THe guy at advanced auto parts said I should disconnect the battery to reset the computer, but I would think the new air flow sensor would fix the CEL (check engine light) if it were the cause. Your thoughts or expereince?
I am wondering if I replace the air/fuel senor between the firewall and the engine? Would this fix these codes? Also, air/fuel sensors are not the same as 02 sensors, correct?
Thanks
Russell
Thanks
Russell
Talked to advanced auto parts guy, who said the o2 sensor must be the same as an air/fuel sensor. They look the same and seem to be located in the same spots.
So I replaced the easy one (located near the front) and reset the light via removal of the fuse. CEL came back on so, I am going to replace the one between the firewall and the engine with the new one I purchased.
I will let the board know in a couple of days.
Russell
Russell
Board, I have changed my o2 sensor between the engine and firewall. It wasn't that bad. It took about 1 hour to do, from pulling out the front sensor (I tried that one first to see if it would fix the check engine light CEL), putting the car up on a ramp to get under it, to replacing the sensor. I tested the o2 sensor with an ohm meter before I removed it. It gave no readings so I replaced it. I will give it a few days to see if that fixes it.
thanks for the forum
Russell
Russell
