ECU Location?
Hi all. Am trying to help a lady with her '93 ES300 and have some questions.
Where is the ecu (ecm) located? Is it hard to get out? Would appreciate any tricks/helpful suggestions.
Also, what is the procedure to pull stored codes--I assume a '93 is OBD-1? I've tried searching but had no luck.
Thanks in advance.
Thanks in advance.
Lexucanafer
![](http://i73.photobucket.com/albums/i240/mitchm331/ECM.jpg)
Thanks in advance.
Thanks in advance.
![](http://i73.photobucket.com/albums/i240/mitchm331/diagnos.jpg)
Short TE1 & E1 of the Data Link Connector 1 (diagnostic port) which is located under the hood, at the back of the engine bay on the passenger side - a small black rectangular box - with a wire, paper clip, etc. to put the ECM into diagnostic mode 1, which will make the CEL flash any stored trouble codes.
Hint: In the event of two or more malfunction codes, indication will begin from the smaller numbered code and continue in order to the larger.
Steps:
1) Turn ignition switch on but do not start engine.
2) Connect terminals between TE1 and E1
3) Read the diagnostic trouble code from the CEL (check engine light)
4) After checking the codes disconnect TE1 and E1 and turn off the display.
Thanks Lexucan, really appreciate the help. Will do the diagnostic mode next time I'm at the car.
But I'm still confused about the ECU. I pulled the under dash cover below the glovebox and saw what looked like computer(s) stacked horizontally with a bunch of bolted in bracing. Seems like it'd be a real bear to access!
Then--to further confuse me-- I found something somewhere that said ECU is under the passenger side floorboard, you pull back the carpet to get to it. I'll look there when I can but the car is on the other side of town.
Help!!!
Help!!!
Lexucanafer
Help!!!
Help!!!
Lexican -1- could not access your reply to Olnick ? Trying to find OBD plug in for 93 ES300 if there is one . 2-Also I am baffled by rough idling ,car shakes only at 1000 rpms or lower ,otherwise drives fine - no lights on .Replaced EGR ,pcv hose -can't identify any leaks,cleaned intake manifold valve ,plugs look good .Any suggestions. Pete in Calgary.
Have problem with air suspension.Everything get in and atart the compressor doesn't start up and rise to H or L on its own. Have to push the button. Then it comes on and rises. Use to do automatically when start truck. What coyld be the problem??
Also how many miles are on the car? That will possible give me ideas about the rough idling.
EDIT: Sorry didn't see that your post was old but it should help others that are looking for the plugs too.
hotwheels1
07-11-12 04:22 PM
