Wierd Clicking noise on rear, left side. I searched!
So I have had my 96 ES300 for about a year now and it has made this noise since the day I bought it. The left Hub has allready been replaced (but I think this may be the issue) and the brakes were just checked out by my mechanic.
Basically what the problem is, when the car gets warmed up and I have been driving around for a while, I notice a click,click,click noise from the left rear side, as I am rolling. This is on even surfaces with no bumps so I dont think it has anything to do with the saybar bushings which seem to be a known issue from me searching for a while
As I accelerate, the clicking noise gets faster. as I slow down, the clicking noise slows down. at first it would only do it when I was on the brakes, but now it is even when I am driving at about 15-25 MPH. I have also noticed that when I am turning left, the noise is louder. I hope that is enough detail.
Brand new tires,
Hub was replaced about 8 months ago,(could be bad though as I can hear a howling noise on the freeway on the left side)
Brakes were checked out and all is good.
What could it be?
Please! My mechanics dont even know what it is. I need help!
Brand new tires,
What could it be?
Lexucanafer
The sound you are describing could be many things but since you've heard it since you bought the car a year ago, it probably isn't a rock in your tire tread...
....that would be too easy.
It could be a worn CV joint or a loose center cap on one of your rims. The caps are held in place by friction and if some of the metal tabs that hold the cap on get bent out of shape, the cap can rattle around as the wheel rotates and cause a clicking noise.
Check the axles for what? Loose bolts? I work on Motorcycles, not Cars. Although I am sure it isn't too hard to work on these things.
