'00 Lexus ES300 P1130
Hello Everyone!
My check engine light came ON and I got diagnosed and the code found was P1130. The mechanic told me that it may be becuase of A/F Ratio sensor Bank1 Sensor1, Spark Plugs, Fuel Injection Cleaning...
I replaced the A/F Sensor(Denso 234-9021) and disconnected the positive terminal of the battery for couple of hours to reset the light... It went OFF but cam back on within 2 miles.... So, then I replaced the spark plugs and did the same thing to reset the light and this time too it came back within 2 miles...
Now I am really frustrated... Anyone has any suggestions for me? Or should I go ahead and get my fuel injection cleaning too?
Thanks!! I appreciate any help.
i fix the car finally it was not the sensor in the front is the one befind the engine by the firewall it was rough to get back there but now the car is running like a baby again if u have any questions hit me up
I had a friend hook up the computer and these are the codes #po125 and p1130
also the car only has 64,000 miles its a 2000 es 300......the main seal is leaking a little and to replace it is very expensive..could I let that ride for awhile? also on start up I'm getting a cloud of white smoke....Man I like the car but whats up with only 64,000 miles....anyone? thanks
Hi, Mine seems to have the same code.....How much is it? and do you have to buy from dealer.... thanks. How did you find it to replace it...
I have same problem as described above. I thought it was oxygen sensor and just replaced it(bank 1 sensor 1). But the code does not go away. Also, there is a strong smell of gas in the cabin. Any ideas?
BTW: I have 2000 ES300.
Thanks.
Thanks.
hksnlper
08-04-10 07:29 AM
mrtentacle
01-26-07 04:49 PM
