Engine NOISE felt on GAS PEDAL HELP!!!
Old 07-03-08 | 02:55 PM
Ariyanna's Avatar
Ariyanna
Default Engine NOISE felt on GAS PEDAL HELP!!!
Heys guys I drive a 1996 Lexus ES300 with 110K on the clock and everytime I drive my car when I'm in drive pressing the pedal I feel all the engine noise and roar on the gas pedal and it just didnt feel smooth. Its even worse when I turn the air conditioning on and I can feel more engine noise on that pedal. Does anyone have any idea or can help me bulls eye this problem thank.
P.S. Also If anyone else is having this problem let me know
Old 07-03-08 | 07:32 PM
tuan92129's Avatar
tuan92129
Engine noise???
Vibrating gas pedal?
hmmm.. My truck was shaky when i had some engine misfiring due to spark plugs..
Did you wash your engine and get water in there?
Old 07-03-08 | 09:43 PM
BadViper22's Avatar
BadViper22
Any CEL's?
Your whole intake plenum and everything on it could probably use a good cleaning. Go buy yourself a can of throttle body cleaner and go nuts (not literally).
Old 07-03-08 | 11:07 PM
vwynn's Avatar
vwynn
check Engine mounts. prolly shot right now. also tranny mount.
Old 07-04-08 | 11:31 AM
Ariyanna's Avatar
Ariyanna
I havent checked my mounts so thats a possiblilty, You think the intake could cause that problem BADVIPER22?
Old 07-04-08 | 03:46 PM
BadViper22's Avatar
BadViper22
Probably not at high speeds. But if you feel anything at idle then yes. Check what vwynn said first because that sounds the most probable, then if that doesn't fix it do what I said. And if it still isn't fixed check back, good luck either way!
Old 07-04-08 | 06:21 PM
Ariyanna's Avatar
Ariyanna
OK when the car is at idle it idles fine, but I noticed that when I come turn the car on after being off overnight it turns over kind of hard, sometime it will turn over smoothly and other times it turns over hard. BadViper22 when I feel that engine noise is when im driving at lower speeds, it kind of goes away after I have reach fourth gear or when im at higher speed when the engine is already coastine. I also noticed when I put the car in drive i feel a slight thump?
Old 07-04-08 | 11:14 PM
MCG33's Avatar
MCG33
Sounds like the transmission mount
Old 07-05-08 | 10:32 AM
llcoolpass's Avatar
llcoolpass
check for an exhaust leak too
but you wouldn't feel it from the motor mounts being worn, in 95% of cases, I know from experience
it's kindof normal for there to be some vibration that you are feeling, it's just that a newer car isolates these better than an old car.
Old 07-06-08 | 10:05 AM
Ariyanna's Avatar
Ariyanna
Well is there a way to physically check the mount for any faults or cracks, cause I drove my uncles 94 es300 and I didnt feel any engine noise on his pedal it felt very smooth and drove like a different car, I felt kind of mad about it. LLCOOLPASS you want to test drive my car to see if you notice anything????
Old 07-06-08 | 02:11 PM
tuan92129's Avatar
tuan92129
Maybe you can just replace the mount anyway?
Maybe its not too expensive...
Old 07-06-08 | 06:26 PM
Ariyanna's Avatar
Ariyanna
I think Im going to have all the mounts replaced its $330 for all original mounts shipped from Lexus in Pembrooke Pines in Florida They were like %30 off of MSRP so at least that a good discount. http://www.trademotion.com/shoppingc...26callout%3D11
energie8
09-14-17 04:08 PM
Ariyanna
01-21-12 06:46 PM
Ariyanna
05-15-07 06:19 PM
