'94 ABS Sensor...Do they fit flush or slip into the spindle casting?
I broke a wire. The shop said left front. I removed the sensor 10m bolt and tugged it off...it came off flush with the spindle casting. I fixed the wire, it passes juice thru both wires again. The light is still on.
Is there a reset....I disconnected the battery for a minute.
Did I break the sensor or do they come off flush?
Thanks,
John
Thanks,
John
I've answered my question.......In reviewing pictures on auto part websites...Yup, I've busted the sensor in half, leaving a stub in the spindle.
I'm hoping I can remove the stub without having to pull the axle out in order to hammer the stub back out of the spindle.
Anyone experienced in doing this? I'm pissed I did not cut the two wires ahead of the sensor and trace for shorts from there...@#$%
JU
JU
