Anyone have bulb #'s for a '94 ES Climate Control backlighting?
I got the same problum man with the climate and the stereo... let me kow what you find out.. how does your instrument panel lights look, i got the same car and mine are all ****.
Theres a climate bulb thread somewhere here.. (search)
The screen bulbs are LED and soldered on (not servicable)
The button back lighting are incandescent and easy to replace.
Lexucanafer
Well, you won't find a bulb for it at the dealer as '"not serviceable"
It is not very easy to do, but here is how.
Once you have the climate control apart, take all the screws out that you see (that hold the front cover to the board). Then I think there are three screws that hold the white lcd housing to the board.
CAREFULLY bend the entire lcd back, using the white housing to hold on to. You will see the place where the three bulbs are attached to the board.
Bend the lcd back enough to remove the white housing completely. It will make it much easier to solder the new bulbs in place with the housing out of the way.
couple of questions:
- is this the same part number (in the thread linked above) for a 2000? same process as listed above by tuan? not comfortable with having to solder bulbs to a panel; if there's no DYI, anyone have this done by a shop?
