99 ES 300 Will Not Shift into OD - Ever
Hi Everyone,
I just bought a '99 ES 300 with 106k miles. The car is in great shape and I had it checked out by the family mechanic when I bought it. His only complaint was that the 100k service had not been done, so I got that taken care of. Now that I've driven it 500 miles I've noticed two things:
1 terrible gas mileage
2 It never, ever shifts into Overdrive
I don't have any check engine lights showing on the dash, but the car turns about 4k rpms going 70mph down the freeway. I can turn the OD button on or off going 70 down the freeway and nothing changes, the car doesn't shift. I have also paid close attention to at what RPM the car shifts on lower gears. Oddly enough, the car shifts into second gear at 4400 RPMs. This seems really low to me. I've also counted the shifts the car does when accellerating to highway speeds and I count three shifts. So either I have a one of a kind 3spd or something is wrong here! So, how much work + money am I looking at for the repairs and can someone point me in the right direction?
Thanks,
Casey
Thanks,
Casey
I've searched. This question has been asked multiple times by different users. Apparently it's still an issue, because no one has responded when the question has been asked!! No one knows the possible cure?
All the searching I have done leads me to believe that it's a sensor. I believe it is the temperature sensor for the tranny. But I can't find that part anywhere (even at the parkplace plano website). And I have no idea how to test or search for that part.....Can someone...anyone...help?
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Thanks for all the replies!
Here's what the problem was:
CEL and Trac off light were not functioning. As were several of the other idiot lights. I never noticed it. Anyway, pulled the panel out and replaced the light bulbs. You can get the light bulbs for the idiot lights from any auto parts store. I paid $3 for 2 of them at o'reilly. After that, I saw the trac light and the CEL were illuminated.
Next, I got the codes read at autozone. It was the knock sensors (Both of them). I also got a code that the "engine was running rich" but I'm not sure why that code popped... I had both knock sensors replaced as well as the wiring harness (also had the the bypass hose replaced while they were in there) . I got all the parts from carson toyota for about $300 or so. Labor was $250. I think I got a descent deal on parts and labor. A cousin of mine owns a shop and he does most of my work. He doesn't give me a "steal" on labor but he's honest and cheaper than anyone else....anyway...
After the knock sensors were replaced I did a tuneup and replaced two of the 02 sensors (just because the car has 110k now).
As a result:
Car shifts BEAUTIFULLY
Car goes into OD
I get 28MPG+
NO CEL
The car runs great, I mean GREAT.
So, for everyone who has had this same issue hopefully this resolves it.
As a result:
Car goes into OD
I get 28MPG+
NO CEL
NovaRacer
13
08-31-10 03:31 PM
rlx101
02-01-09 05:24 AM
