Problems with fog lamps on 97 es300
Old 07-14-08, 08:51 PM
phil97ES3
phil97ES3's Avatar
Default Problems with fog lamps on 97 es300
On the driver side of my 97 es, the fog lamp was not coming on. I tried replacing the bulb and that didn't fix the problem. Has anyone had this problem before? Or can you point me in the right direction on how to troubleshoot this? Thanks
Old 07-15-08, 04:27 PM
phil97ES3
phil97ES3's Avatar
Smile
Well I figured it out, I tested the voltage at the harness and at the assembly. Everything was good, 12 volts, everything looked kosher. In the past, I always found that it really didn't matter if you touched a halogen bulb. It might only take a few days off the life of it. In this case, it ruined the bulb from the start. So I guess the lesson to be learned here is, when someone says don't touch the bulb, it means don't touch the bulb. I put a new bulb in and it worked fine. Boy was that a pain to figure out...
Old 07-15-08, 05:24 PM
jon91se
jon91se's Avatar
bulbs can be weird like that. For the most part you never need to touch it when installing so lesson learned.
Old 07-15-08, 11:40 PM
Choas
Choas's Avatar
Glad you learned your lesson with now rather that later with a $60-$100 HID bulb. Really though YOU TOUCHED THE BULB Oh and welcome to CL don't feel bad about the bulb you being a noob and all with this LOL
InvAsian
04-06-06 09:47 PM
1sxyrxy
SC- 1st Gen (1992-2000)
02-19-06 10:58 AM
Nomis
Lighting
09-16-04 08:54 PM
rukarims
01-19-03 01:25 AM
Quick Reply: Problems with fog lamps on 97 es300
