water leaking into my trunk PLEASE HELP QUICK
Old 07-30-08 | 04:19 PM
happy_es3's Avatar
happy_es3
Default water leaking into my trunk PLEASE HELP QUICK
hey everyone i got my self some dynamat extreme and was going to install it in my trunk today, so last night i emptied out my trunk (sub,carpets, spare tire, plastic,everything....) and didnt really have much time to do anything else so i closed the trunk and left it, now today i parked outside of my works parking structure and it was raining for about 3.5 hours when i went to my car after work and looked in the trunk there was almost an inch of water where my spare tire would normally be , now my question is are there any drain lines or anywhere else critical i can check for this leak? i really wanted to install the dynamat today but it doesn't look like that will be happening also if it helps the car has never been in a collision or anything like that and all of the panels line up perfectly as they did from the factory... any help is appreciated thanks guys
Old 07-30-08 | 11:48 PM
Baybarea's Avatar
Baybarea
Wow, I was gonna do the same thing execpt, mine had been in a collision and the water is not in the spare tire area, but in the left side area and only half an inch of water.
Old 07-31-08 | 04:52 PM
happy_es3's Avatar
happy_es3
okay heres a little update, ive found where its leaking from and im just going to silicone the heck out of it its actually coming from one of the bolts that hold the driver side tail light on (fender piece), i had taken it off a couple months back and i guess it lost its seal or something...
and to baybarea yeah how bad was your rear collision? the only reason i included that the car hadnt been in a collision is because when i called my friend whos a ford tech, he told me that it might be the cause of a rear collision and that got me a little worried... but in the end it was my own stupid mistake o well i guess you live and you learn....
dewana421
ES - 5th Gen (2007-2012)
06-27-23 05:37 AM
E0FLK0PTR
06-22-21 12:15 AM
Oro
01-07-16 02:06 PM
AL13NV8D3R
12-03-14 05:53 PM
95SC3T
SC- 1st Gen (1992-2000)
13
07-08-13 10:06 PM
Quick Reply: water leaking into my trunk PLEASE HELP QUICK
