97 es300 Trac and ABS lights on
Hello all, I'm new to the forums and find them very useful, lots of great info! I have a 97 es with 145k on the odo and my trac off light is flashing along with the solid abs light. I've read a ton of posts about this, but I have different codes than the other cases. I jumped the terminals and got codes 21-26 which all deal with the actuator solenoid. The lights only seem to pop up when either the a/c is turned on or when I hit WOT. I took all abs sensors out and cleaned them, a few had metal shavings on the ends, but the lights still come on. I've also disconnected the battery and turned car on/off several times with no results. Have any of you heard of this particular issue? Thanks for any help!
alcan
02-03-17 04:28 PM
