97 ES with H&R 1.2 drop and IS300 wheels?
I have searched and not found exactly what I needed to know I will be running a 215/50/17. I have a 1- 1.2'' drop.
Will the IS300 wheels (50offset) need extended studs or will a 10mm spacer have enough thread to bolt on gorilla lug nuts?
I already have the tires and have an opportunity to run the IS300 wheels. Im only concerned with the rear. Ive ran 17x7 with a 215/50/17 and 40 offset before fine. Just curious to get the wheels fitted without rubbing will I need the extended lugs or not. Thanks
I had 225/35/18x7.5 in the front +50 and it fit fine but tried to put 255/35/18x8.5 in the rear with +47 and a 10mm spacer but didn't fit only by a little bit. I'm guessing it should fit. I don't know how much mines is lowered haven't checked it but it covers a good amount of the tire in the front and rear.
thanks for replying everyone! The only way it will work is for me to buy the spacers that come with the studs on them. Oh well back to the drawing board. anyone wanna buy my car?
lil' IS300
Wheels, Tires & Brakes Forum
04-24-03 08:07 PM
