Please Help Rear Power windows Stopped Working
My 2004 es330 rear passenger window stopped working. I here it click when I push the switch from the driver seat and rear seat but the window doesn't go up or down. The other 3 windows works fine. What's broken? Please help.
If you hear a click noise, it could be the regulator or maybe the window switch.
Test it out with a test light and see if your getting any power going to the regulator/switch
My 01 camry had a front pass. side go out. It turned out to be the window switch on the pass side. Even though it wouldnt work from the master switch at the drivers side either. Replaced the passenger front window switch and fixed the problem.
05ls430518
02-26-18 08:40 AM
KiNGD206
01-10-14 07:13 PM
