97 ES 300 engine knock
I have 241,000 miles and just recently between 2,000 thru 2,500 RPM there is a knock. It only makes a light knocking noise in that RPM range. No noise under and no noise over that RPM. I tried Lucas and it does not seem to help. The dealer says all the clearance of the valve cups are within tolerance/
Any suggestions??????????????? Punt PASS or Kick
Would a flexplate make knock in the range of 1750 thru 2500 RPM only? If I put it in drive and the knock is still there but not as loud coud it be a flexplate?
I am experiencing the same problem except my car has 179000 miles on it. If you come across any answers please let me know. Thank you. BTW what is a flexplate?
