Will IS250 wheels fit on 98 ES300?
Hey guys, will an 07 IS250 17" x 8" +45mm offset wheels with 225/45/r17 wheel setup fit on 98 ES300?
How well will it fit? I've seen ES with the 18" IS setup, but is there any fender rolling required?
Thank you guys!
Thank you guys!
you will need approximately a 3mm spacer for the rear. research the factory sc wheels, they are same specs, except they are 18" diameter. what kind of suspension do you have?
Goodluck
charley
btw, look for pics of chaos car, there is a new thread, he has the wheels you are looking for i believe? or are you talking about the 5spoke is300? arent the isx50 wheels 18"?
Goodluck
charley
Yup I'm the only one with the is350 18's and its a PITA to do you need either extended studs with 15mm spacers or the kind with them built in. You also NEED to roll or delete your fenders in the rear and some in the front or you will rub bad. You also may have to grind a lil off the inside of the rim like I had to to make them fit without hitting the strut tower. Have Fun
mandae
09-13-12 12:48 PM
abobiznow
07-23-06 09:43 PM
