1998 ES300 [exhaust fumes inside car?]
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
In my 1998 ES300, I have started getting a strong smell of fumes inside the car. I have had the exhaust system inspected by several different techs and they cannot find where it can be coming from or how it is getting inside the car. Has anyone else had this problem? I really like the car and do not want to get rid of it, especially for this reason. Thank you, Mike
I have a similar problem, not sure if its exhaust fumes though. If lets say i get on the freeway and start going past 55, I begin to get this egg-like odor...nasty egg though!!! It happens any day and every day i go past 55.
Generally, a "rotten egg" smell is from a faulty exhaust problem such as a converter starting to burn out or the muffler going bad. It used to happen when regular gas was used instead of unleaded gas. I like to use some "additives" to clean the fuel system, but I am sure one would have to be careful on which ones or safe and which ones are not. On standard transmissions there will be a strong smell if you start "burning" the clutch out. Good luck
I have made sure that the setting is on recirculate. It is mostly apparent when sitting still such as at a red light.
If it smells like rotten eggs, it's from behind the catalytic converter. You can either check for leaks with the car on jack stands, or take it in and have a new exhaust put on from the cat back.
Still, it shouldn't be getting inside. I'd suggest not using recirc and try the "outside air" setting. That air will come from the base of the windshield, and if you have a leak elsewhere, the air blowing out should push the exhaust fumes away. You're from Texas, so I'd guess you don't have a big rust hole somewhere.
Pull the back seat (easy, lift up on the front edge) and see if the drain plugs are still in place. Check around all the door seals and make sure one isn't missing or damaged. Check the trunk seal too, as there is a vacuum at the back of the car when you are running down the highway.
It might also be that your car is running excessively rich, or the fuel you are using simply stinks. Try a different brand from almost empty. If you think it's running too rich, have the O2 sensor checked, or shotgun it (them?) if you're over 100K miles anyway.
Good Luck!
Good Luck!
FWIW, the first exhaust problem to show up in my 98 ES was the flex pipe at the base of the firewall - a very slight leak.
That could be the culprit, as the fumes would blow under and away while the car is moving, but rise up the firewall and into the vent intakes when the car is stopped at a light.
ummm i don't think that is such a good idea to be underneath a car while its running... expecially when its on jack stands. i perfer you stay on the side the car and look from birds eye view.
there is a possibility that your shift cable linkage cover is damage. just a possibility.
it is a cover that covers the outside fire walll so that fumes does not come in.
i have a damage one, so i have no cover from the firewall and the inside so fumes would get in,expecially when i have an exhaust leak at the moment.. its dangerous.
if you want to know where its located... it smack right in the middle underneath the dashboard on the walls.
and i DO NOT SUGGEST STAYING UNDER A CAR WHILE ITS RUNNING....![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
i swap motors and i still don't trust being under a car PERIOD.
Betsy1994
06-26-15 04:29 AM
