Parking brake (ebrake) adjustment 97 es300
Old 10-12-13, 05:31 PM
Lexus66
Lexus66's Avatar
LOL no problem! I appreciate your assistance The last time I worked on drum brakes if I recall correctly the "star" adjustment nut thingy was positioned in a vertical way, so am I reading the diagram correctly? ... UP to contract and DOWN to expand? That's kinda what it looks like ...
Old 10-13-13, 05:25 PM
Lexus66
Lexus66's Avatar
Default Job completed
Okay it's all done! ... I have a few photos but it looks like I may need to shrink them down a bit.
Attached Thumbnails Parking brake (ebrake) adjustment 97 es300-ebrakefix-lexus-es300-004.jpg
Old 10-13-13, 06:07 PM
Lexus66
Lexus66's Avatar
Default a few pics ...
Thanks again for the assistance !!!
*** BEFORE BEGINNING THIS PROCEDURE - make sure that the Ebrake lever is in the down (off) position ***
My lever had 13 clicks ( ... and was pointing nearly straight up) until it would no longer travel, and would barely hold the car at all
After adjusting the rear brakes, the Ebrake handle will now travel 6 clicks, and holds very well !!!
(it was not necessary for me to adjust the cable at the Ebrake -whew-)
remove the rubber plug
align the hole to the bottom as shown
angle the tip of the screwdriver down and push the star spikes downward and away from yourself
once the rotor will no longer spin, reverse the angle of the screwdriver and turn the star wheel the other way - 8 clicks
pop the plug back in and reinstall the tire, do the other side ... count the clicks
the WD-40 stuff helped quite a bit for this project
Attached Thumbnails Parking brake (ebrake) adjustment 97 es300-ebrakefix-lexus-es300-008s50.jpg   Parking brake (ebrake) adjustment 97 es300-ebrakefix-lexus-es300-006s12.jpg   Parking brake (ebrake) adjustment 97 es300-ebrakefix-lexus-es300-007s12.jpg   Parking brake (ebrake) adjustment 97 es300-ebrakefix-lexus-es300-010s100.jpg   Parking brake (ebrake) adjustment 97 es300-ebrakefix-lexus-es300-013s40.jpg
Old 10-13-13, 06:48 PM
PuReChaos
PuReChaos's Avatar
Glad everything worked out.
Old 06-19-16, 08:41 PM
wan8dan
wan8dan's Avatar
I have a 96 ES300. My parking brake handle is loose and needs to tighten up. I am looking for a simple diagram that shows where I can adjust it.
Thanks
Old 06-26-16, 10:57 AM
speedkar9
speedkar9's Avatar
Thanks
Here you go:
VolumeToo
07-13-18 02:40 PM
Doug007
NX - 1st Gen (2015-2021)
07-09-18 11:59 PM
2v1g
12-02-16 06:40 AM
daweeze02
Suspension and Brakes
11-14-09 09:39 PM
IStreefidy
11-14-06 04:37 AM
Quick Reply: Parking brake (ebrake) adjustment 97 es300
