Parking brake (ebrake) adjustment 97 es300
Does anyone have the procedure to adjust the ebrake lever or cable so there isn't so much play in my emergency brake?
Thanks
Thanks
I believe the slack in the cable is related to the rear brake pads. I'm not sure on the 97, but on most rear disc brake vehicles, the emergency brake should be used routinely to keep the rear calipers free. That is if the emergency brake operates that way and does not have separate brake shoes that work inside the rotor.
parking brake.doc
Here's a picture of the setup you have, the parking brake is a rather conventional drum brake as you can see.
I did this a few years ago so my memory isn't so clear.
Basically, the rear brake has both pads and shoes. You will have to remove the rear brake disc. You will have to adjust the inside brake shoes (not the pads) until they almost touch the brake drum.
what georgejet said. but if you want to hear my ranting:
asg, well on my es 300, you have to remove the center console to gain access, i dont know about the 2nd gen es 300 off hand
and after a long time you should adj the cable, 12 years is probably fair.
the rear shoes adjustment procedure is in the 1997 fsm that is on google
first you inspect the shoes and measure them and the rotor [inner diameter/drum portion] to make sure. then you adjust.
then you adjust the park brave lever / cable.
on the 5spd its real important since a lot of us dont like to leave it in gear while it's parked unless we absolutely have to [because of what happens if we forget its in gear when we start it and release the clutch].
on some weird cars in this world, the emergency[''hand'']brake actuates the front brakes. just thought i'd share that.
I was looking for an adjustment know under the console and found nothing, but it doesn't make sense being that it's a floor pedal. It must be the shoes. I use the e-brake every time i park the car, just force of habit from driving a 5-speed in my younger days. The e-brake just doesn't hold the car well anymore even all the way down.
The adjustment is inside the drum area....not under the console. The ebrake operates in the very same way as brake drum. If I remember correctly, applying the ebrake pedal does NOT self adjust. There is NO self adjustment on the ebrake for 97 ES300.
Resurrecting this thread from the dead, the parking brake adjustment is inside them drum area AND under the console (if necessary).
adjust parking brake 1993 Lexus ES300
Hey all! Well I very recently purchased my Lexus and so far it's been great. The center console eBrake handle seems to barely engage when pulled all the way up, so I would like to adjust it. After multiple searches, I have come to the conclusion that I will need to pull the wheel(s?) and adjust the "star" screw or whatever under (through) the rotor ... however, I am not certain if it just needs to be on one wheel or both? Logic tells me it would need to be done at both wheels, but I am not certain about this. Has anyone performed this job and have any input? I would greatly appreciate it!
I did an adjustment on a Camry several years ago and it was all done under the eBrake console area, so I am a bit confused![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
thanks
P.S. This forum is the best !!!
thanks
I believe I found exactly what you need. As to having had any experience doing this myself, I've had none on a Lexus, however, I've done something similar to a Corolla and it was pretty much the same deal aside from the back brakes being just drum brakes opposed to disc/drum.
![](http://img15.imageshack.us/img15/3171/88kc.png)
![](http://img28.imageshack.us/img28/1032/72k8.png)
Priceless, with pictures and everything !!! Thank you very much PuReCHAOS! I will get started on it right away ... however, these instructions do not answer the question as to whether or not this adjustment needs to be done to both wheels or just one, I guess I will just attempt to adjust both of the wheels, if possible. I will start with the drivers side.
