Quick wheel fitment question
Looking to put on a set of wheels on my 2000 ES300. The wheels are 18x8 with a 42 offset. The tires are 225/40/18. Will these fit? They are Volante luxury wheels if anyone cares to check them out.
I have 45mm offset in the rear and after longer studs, fender deleting and 12mm spacers I was able to get rubbing to a minimal. Since you have a 42mm offset you might be able to get away with a 5mm spacer.
in order to get 18x8 to work correctly in the rear...
I'm running a 15mm spacer, this is with SC430 wheels
You will need to trim/roll the rear fender
I also fashioned custom bump stop to make sure not to hit the inner fender lining on hard bumps.
rclab1
04-15-08 11:52 AM
