Please help Engine and trac lights on
Hello all
I am a newbie, have a 99 es300 with 135k miles on it. My engine+trac light came on 3 weeks ago and it went off within couple days . It resurfaced again a week ago and went off within a day. Now since last few days it came back on and i took it to Autozone to get the codes. It was P1135 , P0171 and P0172 all together.The Autozone guy printed out the description of all the above errors. My Gas cap is tight.Checked the air Filter and its not that bad. I do notice the car as if its having breathing problem when i slow down to make a stop.It doesnt die or anything like that. Also my mileage is slightly low after this.
About 9 months ago i replaced 3 coils for misfires and replaced all the spark plugs. A local mechanic suspects the GAS fuel filter could be causing it as it hasn't been changed since last 2 years(20k miles).
Can some one please tell me what could be wrong here.If its a Mass air flow sensor or if its O2 sensor is the problem. I hate to buy both if its not required.
Should i have it scanned by a professional with a computer for more indepth diagnostic report to pin point the failed component? (they charge 50$) .
Also can someone please tell me where these are located (o2 sensors on bank1 sensor 1 or MAF) on the car if i can do it myself and what tools do i need.(to replace o2 sensor or MAF sensor).
If i have to clean the MAF sensor can i do it myself and what do i need to clean it.
Where can i buy these generic parts if anyone can reccomend to put on them ?
Also if its o2 sensor which o2 sensor should i buy , is it pre cat post cat , front or rear (i am confused)
Appreciate all your help in this matter.
aj
aj
Can somoene please help me ? should i replace o2 sensor or MAF ? ..and where they located at. how many are there for this es3000 1999 model..could bad fuel filter cause this?
appreciate it
appreciate it
tomf
12-20-17 04:53 PM
janterry15
04-11-16 05:38 AM
