How to Shadow tail lights?
Old 09-11-08 | 10:16 PM
Parker Gen's Avatar
Parker Gen
Default How to Shadow tail lights?
Hi all. Wondering what's the best way to darken the rear tail lights? Do people use a tint on the outside or a spray or do they pull the rears apart and spray from the inside or what's the go? What's the best way to go in relation to it lasting?
Cheers.
Old 09-11-08 | 10:29 PM
Lazy's Avatar
Lazy
transparent paint (smoke) and get clear coat. (Recommend wheel clear coat for high heat so it won't fade in the sun)
Old 09-11-08 | 11:01 PM
alaskaty's Avatar
alaskaty
you can use VHT Night shades and then a clear coat on top or you can use vinyl tint and lay it over the lense.
Old 09-12-08 | 09:32 AM
HYPERBOY's Avatar
HYPERBOY
vinyl tint!!!! becuz painting them make it permanent...
Old 09-12-08 | 10:06 AM
paintrain's Avatar
paintrain
vinyl. since u can always remove it later if u change ur mind
Old 09-13-08 | 03:25 AM
Lazy's Avatar
Lazy
You can also remove paint just a bit harder. I donno how much to do vinyl to paint and clear coat is like 10$ or less.
Old 09-13-08 | 03:56 PM
RawGin's Avatar
RawGin
99es3 did you just do the red parts of the light, or did you do the whole thing?
Old 09-15-08 | 09:29 PM
Lazy's Avatar
Lazy
just the red.
mixa86
08-11-12 09:47 AM
OaklandLex
SC- 1st Gen (1992-2000)
13
05-11-10 05:19 PM
ewingli
11-04-07 08:29 AM
nnnickkk
32
08-15-07 10:35 PM
Raphael M
04-16-07 01:49 AM
