01 ES300 Rear sway bar - TRD or whiteline
Finally decided to upgrade RSB but ran into some problems.
Using 01 Solara V6 as X-ref, I found the following for my 01 ES300.
Whiteline:
Rear - BTR39 - 20mm - solid
TRD:
Rear: p/n PTR06-06990-10 - unkwn - hollow???
Which is better? Do I need any thing else or is it plug and play? I know that Whiteline will come with bracket and bushing but not sure about the TRD.
Also, where is the best place to get the TRD?
Please help!
Whiteline:
TRD:
Please help!
I didnt know there was a TRD Rear sway bar that would work on the ES. But you can get TRD parts from these websites:
http://www.trdpartstore.com/
http://www.trdparts4u.com/
http://www.trdtoyotaparts.com/
-Smitty
-Smitty
Thank you so much for everyone comment.
Just want to confirm if TRD Part # PTR06-06990-10 is the correct one before I order.
And BTW, is there any special caution / note for installation?
neegroy
13
10-17-14 06:06 AM
LasVegasGS
04-02-05 12:07 AM
