97: changed plugs for CEL p0300 and p0302 but no avail
hello there. ive used bosch plugs before and they all went bad when seafoaming my car, so i replaced them all with new bosch's about 6months ago as a last minute resort. and 4days ago i noticed the vehicle start to stutter, and the CEL came on. went to autozone for testing, and codes p0300 and p0302 were pulled. so today i changed that spark plug on cylinder 2(closest to the front of vehicle on passenger side). after driving away, it started to sputter again after about 3miles. the person at the counter at first said it may be the coil pack for that cylinder. could it be. this is for a 97. and stated that i would just need to replace that coil pack(located right above the spark plug). does each cylinder have its own coil pack? sorry, im not familiar with coil packs, because from reading, member pheonix stated that there are 3 coil packs, 1 for 2 cylinders. and follows as 1-4, 2-5, 3-6
Thanks
Charley
Thanks
Charley
Super Moderator
Thanks
Charley
Thanks
Charley
P0300 is a random cylinder misfire error that usually is accompanied with another P03XX. You are correct on P0302 and it pertaining to cylinder number 2 and its location. The front cylinders are 2, 4 and 6 from left to right and the rear ones are 1, 3 and 5 from left to right. If you think of a stick shift, that's pretty much the same way.
As far as it being a coil pack, I'd highly agree, I use to run carb cleaner in my RX300 and had a blown coil as a result. My uncle and I actually pulled out the ignition coil with the spark plug still attached and started up the vehicle and no spark would appear, confirming a bad coil.
ok. i think it is a coil pack, but i will go back to autozone now to pull codes again. yesterday replaced spark plug, after leaving about 3 miles away on my way to school. code poped up agian. so after school, went back, and had codes pulled again. same codes. so i removed the coil pack for testing, but the guys at the counter said they couldnt do it because they dont have the correct information to check on the voltmeter. so i swapped coil pack 2 and coil pack 4 and disconnected the battery to clear codes and drove around the block, and problem went away. well this morning got in my car for school, and instantly started stuttering and CEL came back on. im on my way to get it checked, but hopefully it will pull up as p0304 instead of p0302, confirming a bad coilpack. wish me luck. lol
Charley
Charley
Super Moderator
Charley
Charley
Has a similar problem about 2 weeks ago after I changed OE Denso Iridium to NGK Iridium IX. I got random miss fires and cyl 1 miss fires. Swapped coil pack, replaced NGK on cyl #1 with old Denso, problem fixed. It was the defective NGK plug - made in Japan.
Dump the Bosch - well known for sucky quality in Honda/Toyota and get Denso OE Iridium or Denso Power.
I will use the NGK IX for another 1k then will go back Denso OE (70k life) or Iridium Power (30k life).
update, ok, well after bringing it back to autozone. and scanned, now its p0304. so i have a bad coil pack. anyone know of good places to get them for better pricing for oem toyota?
yeah, these bosch's suck a lot. just that right now with no money, i cant even think about spending on something that i dont need, but thanks for the heads up.
Charley
Charley
