1998 ES300 Radiator Fans are constantly on
Old 09-26-08 | 03:39 PM
inta251's Avatar
inta251
Unhappy 1998 ES300 Radiator Fans are constantly on
Hi all,
Can someone please help me with this problem, I appreciate it.
When I try to start the car and just turn on the key, but not all the way to actually start, the fan start at a full speed with a full blow of air. Even the car is parked inside the garage for two days and the engine is dead cold.
Tried to check the relay for the fans, swapped them with no luck. Aren't those fans suppose to come on when the engine gets hotter ?
Can someone, please guide me to fix this problem.
thanks in advance !!
Old 09-26-08 | 04:13 PM
JSM1284's Avatar
JSM1284
Is your AC on? The Condensor fan operates whenever the AC is on...
Old 09-26-08 | 04:58 PM
inta251's Avatar
inta251
No, AC is off. Engine is complete cold, its just fans never stop running
Thanks for the help
Old 09-26-08 | 05:06 PM
JSM1284's Avatar
JSM1284
Check the Engine coolant temperature sensor
Old 09-26-08 | 05:07 PM
JSM1284's Avatar
JSM1284
Inspect No.1 ETC switch.
Drain engine coolant.
Remove the ECT switch.
Using an ohmmeter, check that there is no continuity between the switch terminals when the coolant temperature is above 98°C (208°F). If there is continuity, replace the switch.
Using an ohmmeter, check that there is continuity between the switch terminals when the coolant temperature is below 88°C (190°F). If there is no continuity, replace the switch.
Install the ECT switch.
Fill with engine coolant.
Inspect No.2 ETC switch.
Using an ohmmeter, check that there is continuity between the switch terminals when the coolant temperature is above 94°C (201°F). Using an ohmmeter, check that there is no continuity between the switch terminals when the coolant temperature is below 83°C (181°F). If continuity is not as specified, replace the switch.
Ihussain
06-16-18 05:43 PM
msweber97
10-27-13 05:43 PM
Mvinhie
10-08-13 09:55 AM
kmy
10-31-12 05:54 PM
Lexicon1
SC- 1st Gen (1992-2000)
11-06-05 09:26 PM
